I'm asking this to gauge if this is feasible / worth doing... We need a new sliding door, to replace the existing 1800 slider. The space available is precisely 1800mm, not the standard 1810. We have a new sliding door 1810w, but to make it fit 5mm would need shaving off the brick on both sides. On the exterior, the metal frame of the sliding door is attached directly to the brick. Inside, is a timber door jam. Photos show this.
My question, is it feasible to shave off the 5mm on the bricks behind the frame (leaving the exposed brick untouched)? I'm not sure how this would be done, but I imagine the need to remove the timber jam on the inside and place the door in position from the inside.
Using this door would be a substantially saving to us, but shaving the brick something that is generally done if needed?
Thanks.Exterior - Metal frame up to brick
Interior, timber jam
Hello @geoffr
It is possible to cut your brick wall as seen in this guide - How To Cut A Brick Wall Opening. The techniques used are applicable to your project. My best advice is to cover all the items in the vicinity with painters drop sheet and fixed in place with masking tape as the cutting activity will generate an extreme amount of dust.
Please remember to wear personal protection such as thick clothing, closed toe shoes, gloves, goggles and a mask to protect you from the dust and debris that will be flying while you cut the brick.
Ours would only require a shave, not a complete cut out like the video. What tools would be used to achieve this?
Thanks.
Hello @geoffr
For a very clean cut I suggest using a For Hire: Coates Demolition Saw - 24hr. I understand that you only wish to cut 5mm off each side. This can be achieved using the demolition saw, but if you prefer something smaller you can use a small handheld grinder with a masonry blade attached. The only other tool that comes to mind is a Trojan 115m Brick Bolster. Keep in mind however that this tool will sometimes take too much off when angled in the wrong direction.
