Tile to laminate transition - hidden attachment of transition strip
percyferry
New Contributor
Re: Tile to laminate transition - hidden attachment of transition strip
The Roberts Magic if [TM] are supposed to work. However, instructions are sparse and the ones included are wrong! Bunnings will tell you you need a 6.5mm drill, or hammer drill if you're going into masonry, but you actually need 6mm bits. I tried the 6 5mm and the trim was loose and the "magic plugs" were damaged in the removal. Dollars later, a builder told me to use 6mm drill bits. That works, but the magic plugs are fragile and break or bend very easily. These plugs aren't magic, except the price of them seems to come from some fairytale. They would be great if they were brass or steel. But they're not.
percyferry
New Contributor
6.5mm drills are too loose. Use 6mm.
Many thanks for joining in the discussion and sharing your experience @percyferry. We are looking forward to reading more of your posts soon. Please don't hesitate to post whenever you have something to share or need a hand with a project around the house and garden.
Welcome to Workshop,
