How to clean timber door with sticky residue?
amichaelmedia
Building a Reputation
Any tips for removing  old sticky decorations from Easter on door? They were adhesives from Kmart
Re: how to xclean timber door?
Hi @amichaelmedia,
What have you tried so far to remove the sticky decorations? Bunnings stocks a range of sticky residue removers that can work well, but many are quite strong. It’s a good idea to test any product first in a small, hidden area of the door to make sure it doesn’t damage or discolour the timber’s finish. Once you’re confident it’s safe, you can proceed to remove the rest of the adhesive residue.
I recommend you try either Goof Off 177ml Adhesive Remover or De-Solv-it 125ml Sticky Spot and Stain Remover. Use them sparingly, and remember to do the test, as they could strip the coating off the door.
