Ensuite basin fix
rof71
Ensuite basin fix
Can any one help suggests which product, there was push button drain plug, but I want to replace with normal plug set
do need to silicon any where or is there a rubber seal available
Tony
Re: ensuite basin fix
Hi Tony (@rof71)
Welcome to Workshop. We're pleased to have you join us.
I suspect that for community members to provide helpful advice you'll need to provide a lot more information about your problem and the basin itself. Could you please clarify?
Many thanks,
ProjectPete
You just need something like this @rof71 https://www.bunnings.com.au/caroma-40mm-white-plug-and-waste-with-spacer_p4920650 Take a look at Bunnings and you should find a chrome/black set with "normal plug".
Make sure you get the right diameter set - 32 or 40mm.
You should get everything you need is in the package. Make sure there are 2 rubber flanges.
The rubber flange sin a snug fit should prevent any leaking but just add some clear or white silicone if needed.
Handy and helpful
