Hardie board sheets ceiling. Several bubbles appeared probably due to the rising heat from the BBQ which has now been moved. Bubbles removed, which was the original surface of the hardie board but has now left a slight indent in surface where each bubble was. What is the best Bunnings product to fill the indents back to a flush surface ready to paint.
Hi @brengun
I would use Gyprock CSR multipurpose joint compound
It is quite inexpensive and stays fresh for other dent repairs etc. Best of all non-shrink and easy to sand by hand or machine down to a feather edge.
Other fillers out there just as good too. ![]()
Hi @brengun,
@Jewelleryrescue has already provided the advice I would have given.
The Gyprock CSR 2.25kg Less Mess Multi-Purpose Joint Compound is a fantastic general-purpose plaster compound that will be perfect for this application.
Give the plaster compound a good mix before applying it with a plaster knife. You're aiming for the plaster to be smooth and sit perfectly flush with the surrounding areas. Once dry, give it a sand with a sanding sponge before painting.
