How to replace fluorescent light fixture?
KatG
Hello,
Long time lurker, first time poster! This is the light in my European laundry. It was there when I purchased the property. If I purchase the Brilliant 60cm CCT White Tradie Tri-Watt LED Batten Light would it be an easy straight forward swap over for an electrician? The current fluorescent light fitting is 60cm. Or is there a a different product that would be more suitable?
Many thanks,
Katherine
Re: How to replace fluorescent light fixture?
Hi Katherine (@KatG),
As there is an existing batten light, we can assume there is a good mounting point as well as the necessary cable to run a batten light.
Put simply, yes, it would be relatively simple for an electrician to swap the existing fitting for a Brilliant 60cm CCT White Tradie Tri-Watt LED Batten Light or any other similar fixture, such as the Brilliant 60cm White Kenton LED CCT Batten Light.
KatG
Thanks very much for your quick response Jacob. I'll go ahead and purchase.
