Hello Everyone,
I am currently doing a reno on my laundry and need to replace the cement sheeting on the floor, which is the best one to use? I have floor boards over the top of the floor joists so looking to lay the cement sheet then tile. The laundry is 2.5M x 1.5M. Any advice would be appreciated.
Regards
Rick
Hello @rick6947
I suggest having a look at James Hardie 1800 x 1200 x 6mm 2.16m² Ceramic Tile Underlay Flooring. It can be used in internal wet and dry areas and is easy to install. It is an excellent internal underlay for ceramic tile finishes that helps protect against movement that occurs naturally in timber, particleboard and plywood substrates.
Thank you for your advice Eric much appreciated.
Regards
Rick
