Hi Team,
Im replacing a subfloor in my bathroom and getting conflicting info in what i should be using. Ill list my project below
Questions I have
Im getting trades to do some of this, but will do evrything I can myself.
I would love some help with this please! Any other information and tips would be great.
fiber cement sheeting is your best bet for any wet area its just very very heavy so prepare to have someone help
then you will need to
waterproof
lay screed
waterproof again
then tile
Welcome to the Bunnings Workshop community @Garen. It's brilliant to have you join us, and many thanks for your question about bathroom subfloors.
As @chriscam82 mentioned, the standard modern approach would be to use Hardie's Secura compressed cement flooring. It will be laid directly onto the existing joists, though some changes/additions might be needed to accommodate them. Here's the installation guide.
You could use Hybrid Vinyl in non-wet areas, though vinyl sheeting is not an approved flooring for a bathroom.
Here's another useful guide: How to plan a bathroom renovation.
Hi @MitchellMc, I'm in a similar project, but I already removed all wall and subfloor.
From your answer I understand cement flooring (Hardie's Secura) will be the recommended way to go. A few more questions:
1) is it recommended to tile directly over Secura sheet or is better to add in a tile underlay or mortar/cement mix?
2) for wall, is it better to go with Aquacheck (or similar) or Hardie's Villaboard?
Thanks!
Martin
