How easy is Bunnings adjustable gate to install?
philbyone
Growing in Experience
Hi
Im hoping to erect a gate on the back of my carport. I’ve see the Bunnings adjustable gate system. Is it easy to set it up?
philbyone
Re: How easy is Bunnings adjustable gate to install?
That looks good. What size wooden post would you recommend?
An 88 x88 H3-treated Pine post would do the job, if it's above ground level @philbyone. If it's going to touch the ground, you should move up the treatment to an H4 post.
philbyone
I notice the kit recommended for my gate has the steel frame ONLY around the gate perimeter. Can I get a stronger framed kit for greater security
phil
Hi @philbyone,
I'm sorry, but I'm not entirely sure I understand your question. The frames are constructed of steel, and a steel horizontal cross-member runs through the middle. Your timber boards are then attached to the top, middle, and bottom sections of the frame. That creates a strong frame and a secure gate.
Was there something about the construction that you were concerned about?
philbyone
Thanks Mitchell
I’m hoping to install a gate,
It has been suggested I purchase kits for Rapid Fence 1800x1870 and 1200x 1870 for a Gate Fence. My question is can I purchase a system with more steel in the structure other than just around the perimeter?
philbyone
I followed the picture I was sent rather looking your words, the picture doesn’t show the metal middle cross bar.
so I guess it will be secure enough
phil
Hi @philbyone
I am unable to find any picture of the gate system that doesn't have the middle cross bar. If you could share those with us, I can take a look. However, the frames that Jacob suggested both have the middle horizontal cross bar. It's also present on the image you uploaded on the first page of this discussion.
philbyone
Thanks Mitchell
I now see the cross centre piece. It looks as if it will be strong enough
Phil
