How to fix cracked shed floor concrete?
spog777
SL370580.JPGSL370582.JPGSL370583.JPGI am about to try and fix the crack in my shed floor which is about 15ft long and in a "Y" shaped split. I have
studied the approach I need to follow but am confused as to what filler would be the best to use. I am also using
my shed as the guinea pig to acquire skills before tackling my son's undercover garage as I would hate to make
a mess of the floor of his "new" home. I will be painting the both floors to add a nicer finish to the whole job as well.
Re: Cracked Shed Floor Concrete
Hello @spog777
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your cracked shed floor.
I suggest giving your concrete floor a thorough wash with a pressure washer to drive out all the dirt and debris in the cracks. Once the floor has dried off, I suggest using Earl's 1kg Concremate Expanding Cement. It can fill in large and small cracks and because it is cement based and has the same properties as the concrete on your shed floor. Which means that you won't have to worry about the filler being incompatible with concrete sealers or coatings.
Will I need to pack the crack with backing or just apply compound directly?
Hi @spog777
There is no need to pack the crack, apply the compound directly and smooth out as best as possible.
spog777
Re: How to fix cracked shed floor concrete?
Job looks great and nice and level and stable - considering painting the floor once I 20250805_132817.jpg20250805_132823.jpgam finished to make the jobs look nicer
Nice work @spog777, the crack repair has come up nicely.
It looks like it is pretty much good to go if you'd like to paint it.
Check out How To Paint Concrete Floors for some guidance on this process.
