I have a sack truck with pneumatic tyres.
recently I repaired a puncture in the tube, which I checked in a bucket of water and all looked good, no leaks.
After I put the tube back in the tyre and pumped it up, it went flat immediately, within 10 seconds.
So I took it out and checked it again, no leaks. I even stood on the tube, wiggled the valve, pushed and pulled the tube. No leaks.
Put it back in the tyre and it goes down working 10 seconds.
How is this possible?
I even tried the tube with the rim only, no deflation.
Tried also the tube inside the tyre only (no rim). No deflation.
I am now very frustrated.
How is it possible that the tube is fine until I put the whole thing back together (tube, tyre, rim), and then it deflates?
Hello @Drammen
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your pneumatic tyre.
Since you've done all the checks for leaks the only possible point where the leak is occurring is the patch itself. When the tube is inflated outside the tyre the patch stretches and settles flat on the surface of the tube. But once inside the tyre the rough interior surface of the tire stretches and pulls the patch open allowing air to go out.
I propose removing the current patch and re-patching it with a new one. Let the patch properly settle and cool off before inflating the tube. Do another water bucket test, but this time do it deliberately in a slow fashion. Examine every millimetre of its surface to make sure you don't miss anything. Once you've secured the tube install it back into the tyre and test again.
Good Evening @Drammen
I can feel your frustration 😕 and yeah I would be there as well as you have stepped through the same steps I would be trying.
I like @EricL's suggestion and would definently try that.
As another option I would check the inner side of the tyre for any abraisions or marks. The weak point seems to be when the pressure is on and its back in place. I am thinking that something is being compressed with the refitting process, even down to the tube once inserted within the meatl hole of the rim and kinking?
Hi @Drammen
The common denominator is the tyre itself so, thats where I would be having a closer inspection around the lip and the inside surface.
