How to install deadlatch on inward-opening door?
Walcott
Hi
I have bought a Lockwood 001 Double Cylinder Deadlatch for an outward opening door. The door that I need to replace the lock on is inward opening.
Is there a way to convert the lock mechanism to use with an inward opening door?
I do not want to buy another lock.
Re: door latch
Welcome to the Bunnings Workshop community @Walcott. It's terrific to have you join us, and many thanks for your question about deadlatches.
Would you be able to link us to the product you've purchased so we can check the instructions? Deadlatches are manufactured specifically for inwards or outwards opening doors, and they typically are not universal and cannot be converted.
You'll find that just about all deadbolts on the shelf are for inward-opening doors with the key lock on the outside of them. It sounds like you have an outward-opening door (the actual door opens outward) and a standard lock for a door that opens into the home. You'd likely need to return the current lock and Special Order in the correct one.
Re: door latch
Hi @Walcott
Yes the latch can be reversed, I've had to do it once myself a very long time ago and is actually pretty easy . . . . when you know how.
I followed this short Australian instructional video by an actual locksmith.
Nailbag.
Nfollowing this video
