I’ve just had a shed installed and was told to sweep cracker dust into the gaps between the pavers but have also read about pacer sealant.
Should I use cracker dust and leave unsealed?
Fill with cracker dust then seal?
Just seal without cracker dust?
Many thanks
Hello @DIY_Gail
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about sealing your pavers.
If you wish to protect the surface of the pavers, I suggest sealing it. Other than cracker dust, you can also use Easy Mix 20kg Paver Bond Polymeric Sand or the classic sand and cement mixture to fill the gaps in your pavers. The general process is to install the gap filler of your choice and then cleaning the surface of the pavers. Once the surface is clean you can then apply the pavement sealer.
Here is a handy step-by-step guide: How To Seal Pavers
