Which drill to buy for a novice?
handyma
Newbie
I’m looking for a reasonably priced cordless drill to help me with putting flat packs together. I will not be using this for any major building works nor will I use it often. Your recommendations would be appreciated as well as things I should be considering. I am a complete novice in this space. Thanks
sunnyluna
Newbie
Re: Which drill to buy
Hi, I'm new here too. I bought a ryobi one + drill for $99. It awesome and so easy to use
Neo19
Experienced Contributor
If you are just going to put flat packs together, would you even need a cordless drill or something like this would do?
https://www.bunnings.com.au/ozito-3-6v-cordless-screwdriver-with-usb-changing-base_p6290559
If you are after a reasonably priced cordless drill kit, only occasional low intensity use, I think this would be more than sufficient.
https://www.bunnings.com.au/ozito-pxc-18v-drill-driver-kit_p0124077
and something like this.
https://www.bunnings.com.au/ryobi-56-piece-impact-drilling-and-driving-set_p0018722
It's wonderful to have you join the Bunnings Workshop community @handyma and @sunnyluna.
It's also great to see the helpful suggestions from @Neo19.
@sunnyluna's suggestion of the Ryobi 18V ONE+ 2.0Ah Drill Driver Kit would be a solid choice that could also be used for many different projects around the home. Today it might be flat-pack cabinetry, but who knows, maybe next week that shelf might fall off, you'll want to hang a picture, or that squeaky door hinge finally gets too annoying. The other thing to remember is you're not just buying the tools but the battery and charger. You might not use the drill often, but since you now have the Ryobi battery and charger, you can select from any of the 100 tools in their One+ range without having to repurchase the battery and charger.
The advice here likely has you on the right track, but feel free to check out the guide: How to choose the right drill for the job
