Bird house construction project
JacksProjects
We decided to try a different approach to this Bird House Construction Project. Our last attempt failed to provide a safe place for birds to nest.
Apparently reducing the size of a possum box design makes a perfect resting place for small possums. We've had two use it so far.
This time we used some pre-cut marine ply and upcycled some wood scraps to make our improved (and hopefully bird friendly) version.
Materials
Marine Ply
Scrap wood
scraps of dowel
scraps of quad
scrap of plasterboard angle
Blue House Paint
Screws, Nails and PVA / Wood glue
Tools
Drill
Screwdrivers
Hammer
Paint brushes
Clamps
Steps
Step 1
The essential BLUE paintThe essential BLUE paintLooking for inspirationLooking for inspirationMeasuring and marking where to cutMeasuring and marking where to cut
We started with some pre-cut marine plywood and Jack painted them BLUE!
We looked at a birdhouse Jack bought online, to give us some ideas on shapes and sizes. We then measured and marked the wood, ready for cutting.
Step 2
We had the pieces cut to size, some quad for extra support, and a base to help everything stay in place while we put it together.We had the pieces cut to size, some quad for extra support, and a base to help everything stay in place while we put it together.We had fun working out where each part went.We had fun working out where each part went.
We had fun working out how it went together.
Step 3
We did some gluingWe did some gluingWe did some screwingWe did some screwingWe added some dowel perchesWe added some dowel perches
Step 4
We glued supports from scraps onto the roof peicesWe glued supports from scraps onto the roof peicesWe nailed them on, and when it didn't work, we pulled the nails out and tried againWe nailed them on, and when it didn't work, we pulled the nails out and tried againWhen we got the roof into position, we used clamps to hold it in place while the glue dries and filled the gaps with scrap wood.When we got the roof into position, we used clamps to hold it in place while the glue dries and filled the gaps with scrap wood.
Step 5
We used some scrap plasterboard angle spray painted BLUE to cap the roof peak.We used some scrap plasterboard angle spray painted BLUE to cap the roof peak.We think it looks great.We think it looks great.We hope some birds move in soonWe hope some birds move in soon
Re: Bird House Construction Project
Hello @JacksProjects
Thank you very much for sharing this wonderful bird house project. I think this is the bluest bird house I have ever seen. I'm sure you'll get eager tenants coming straight away to occupy this beautiful house.
Again, thank you for sharing this project.
