Can you paint a plastic pot?
brendawebster44
Making a Splash
hi , I have bought so many plant pots only to find they are too small once the plant needs repotting. I was wondering if I could paint the bigger plastic pot and not poison the plant in it
Re: plant pots
Hello @brendawebster44
If you are painting only the outside of the plastic pot, it should be ok. I suggest using sandpaper on the plastic pots to remove their shiny finish. This will allow the paint to adhere to the body of the plastic pot. I recommend using Rust-Oleum 340g 2X Ultra Cover Paint+Prime Gloss White Spray Paint or your preferred colour to go over the plastic pot. Do not spray the inside of the pot only the outside.
You can also get specialty Spray Effects that mimick marble, gold, and granite finishes. I recommend going to the spray section of the paint department of your local store and check out all the options available.
Let me tag our experienced members @prettyliving and @craftyhopper for their recommendations.
Re: plant pots
Hi well thanks so much for replying but when I looked through my paint left overs couldn’t believe I found prime and paint left over for inside or outdoor in Magnolia mixed it with some leftover blue from a small pot just a tad and will use that. Never the less I felt better knowing I was ok to do so . Thankyou so much b🌺
Re: plant pots
Hi @brendawebster44
It's good to know that you've got some leftover paint. Please don't forget to post an update once you finish your project. We look forward to seeing your painted flower pots.
Re: plant pots
hi Eric and everyone, I didn’t really have time today to do much of anything. I deliver for people who can’t get out for one reason or another. Anyway a lady in the group suggested painting it with a textured paint. So ran around thinking I have all that except the textured paint. Checked the garage and I had all the correct types of paint except they weren’t textured. Emm! I can’t get anything from Bunnings too late we’ll I will make it myself, and I indeedie I did. Photos tomorrow and I bet no one guesses what I did. When I get a few guesses I ll tell you and see what you think. Necessity is the mother of invention.b🌺
Re: plant pots
Hi Eric, I certainly will show you my plant pot , I tried two colours but didn’t like them. Then I found some inside outside semi gloss enamel and mixed it with a secret ingredient to make it textured. I want to see if anyone can guess what the secret ingredient is but if I can learn how to send a private message i will tell you. I have one more step to finish it but it is not easy when I have so many things to do as well. I took your advice about the paint on the concrete but just to see if it worked I tried some goof off I bought from Bunnings ages ago and my wire brush (I had a injection into my hip so I could bend down) and it came off so easily then just hosed it down. Thankyou for all your advice and faith in me brenda
Re: plant pots
@brendawebster44   Looking forward to seeing the pic and having a guess at what you textured it with!
Re: plant pots
I can’t wait to show you, I just want to waterproof it tomorrow and it’s all yours. Just remember I can’t always afford to buy what I would like so a good imagination is key, yours b🌺
Re: plant pots
Well here goes, what is the secret ingredient in the paint
Re: plant pots
Excellent work, @brendawebster44! You'll have to let us know your secret ingredient, but I'm also keen to see if our members can guess.
Many thanks for sharing.
