How to connect garden hose to soaker hose?
Michael1111
Elbow connector male/female 12mm to connect garden hose with soaker hose
I would like to find an elbow connector, preferably metal, that can connect this 12mm male soaker hose to a 12mm female garden hose.
oSoaker HoseSoaker HoseGarden Hose ConnectionGarden Hose Connection
Re: Elbow Connector
Hi @Michael1111,
Unfortunately, I am not aware of an elbow connector that could be used to directly connect your garden hose to a soaker hose.
You could connect a Holman 12mm Brass Sprinkler Adapter to the garden hose, then connect a Brasshards 20mm Brass Male / Female Threaded Elbow LF to the sprinkler adaptor. You could then attach a Holman 12 x 20/25mm Brass BSP Tap Adaptor to the male thread of the elbow and use a Holman 12mm Double Ended Hose Connector to connect the soaker hose to the other end.
Physically, it can be done, but it would require a few adaptors that would make the connection rather bulky.
Let me know what you think.
Re: Elbow Connector
Thank you very much Jacob.
AlanM52
Re: How to connect garden hose to soaker hose?
Hi @Michael1111,
Visit your local store and find this in Aisle 22, Bay 16.
Ask someone for help to adapt that so the tap side also has a click-on hose connector.
Thank you Alan. May I please ask are you able to provide a link to a "click on hose connector". Otherwise the store assistant will just stare at me blankly and say they don't have it and don't know what I'm talking about.
AlanM52
I can't remember exactly what I used because I found what was needed in a box of garden hose and irrigation fittings and adapted a few of them to use both front and backyard. I did another search using 'snap-on hose fitting' and found exactly what you need.
Pope 12mm Swivel 2 Way Snap-On Coupler
I don't think that particular Pope item was available about 5 years ago when I was looking or did not use that specific search criteria.
Anyway, you are good to go...
Hopefully, @AlanM52 can provide a link to the product he is referencing. I'm not aware of anything that would suit.
The easiest solution I can think of is to pop a two-way hose coupling into the brass fitting, which will then allow you to use a Pope 12mm Swivel 2 Way Snap-On Coupler to connect your hose and soaker hose at right angles. It's similar in principle to what Alan has referenced.
Edit: Alan beat me to it.
Thank you Mitchell, I have ordered these.
