Ive been meaning to do this for a while - My front yard only has x1 impact sprinkler - it really needs at least x2 (my backyard has x4 semi-permanent ones I already put in)
I finally got around to installing a extra permanent front sprinkler yesterday, and I replaced the old existing one as well which was leaking underground with bad connections and had a leaky rusted out thread where the sprinkler screws on as well.
The job took 1 hour with some 19mm poly pipe,19mm hose clamps, 19mm elbow, 19mm T piece with a female 15mm connector, 19mm elbow with a female 15mm connector, 1200mm long "risers" with 15mm "joiner" connectors screwed onto the end so I could screw 15mm impact sprinklers on (all from memory I think its correct though lols)
Thought I would post up the job so I can see the improvement (hopefully) in my front lawn next summer ![]()
Hi @Bryan_at_Goolwa,
Welcome to the Workshop community. We're really pleased to have you join us and trust you'll get loads of helpful advice and inspiration for your projects around the house and garden from our clever and creative members.
Let me tag @TheSaltyreefer so he is alerted to your post about your pop-up sprinkler. Hopefully he'll be able to kick off the discussion.
Please feel free to post anytime you need a hand or have something to share. And let me know if you have any feedback about how we can improve Workshop for you.
Thanks,
I believe you should change to pop ups you would save on water and you would not be watering concrete .it is a good idea that you have it just needs refing all you need to do is measure your yard and draw to scale and the take a 10 lt bucket and time how many seconds to fill that bucket .
eg if it takes 20secs to fill formula (60secs/20)x10lits =30lts min then you then check the pop ups what distance they do and how many ltsper min usesd then you work out how man sprinklers you can use at once
Many thanks for joining in the discussion @citerzen. It's great to have you join the Bunnings Workshop community. We are looking forward to reading more of your posts soon. Please don't hesitate to post anytime you have something to share with the community or need a hand with a project around the house and garden.
Welcome,
