Hi all,
Earlier in the year I painted my kitchen cupboards blue with the White Knight Laminate.
They are in perfect condition, however I am now wanting to change the colour... I used the prep coat and then the top coat colour - I did not seal them with the 3rd layer Clear option.
Q: Can I just paint over the blue layer with another White Knight 'Paint' step in the new colour - without having to reapply the primer coat and sanding?
Welcome to the Bunnings Workshop community @gbooth. It's wonderful to have you join us, and many thanks for your question about painting cabinetry.
There is no need to prime; that's only for laminate surfaces. You should use 240-grit sandpaper to de-gloss the surface by lightly sanding it, then remove all residue. You'll then be able to apply a new topcoat. Be advised that if you're using a darker blue and plan to transition to a lighter colour, it may require several coats to block the existing colour fully.
Amazing thank you!
From your link I should still be using the Renew range?
Cheers!
Yes, I'd stick with the Renew range @gbooth as it's a durable product designed for the wear and tear you see in a kitchen.
