Carpet Grippers Sticking Through Carpet
Moe
Hello,
My newly installed carpet has lots of spikes (aka carpet grippers) which can be felt along the perimeter. I cut my foot the other day accidentally when my foot moved near the skirting board. It was quite painful.
Does anyone have any advice about how to manage the spikes protuding through the carpet? I understand these spikes are holding the carpet taut but I'm worried that I or someone else may cut themselves again.
I'm worried that if I hammer the spikes with the mallet they may go down completely and stop holding the carpet taut.
Does anyone have advice on how these spikes can be managed? Is there a tool which can be used to point the spikes sideways? Or some other solution?
Appreciate any help or feedback.
Re: Carpet Grippers Sticking Through Carpet
Hello @Home4us
Thank you for providing that information. The measurement of 3/8 refers to the thickness of the carpet padding and the 5LB is its density rating. If we convert 3/8 inches to millimeters we get roughly 10mm. Plus the thickness of the backing of your carpet you will get your overall thickness.
So if for example, we have a thickness of 10mm for carpet padding plus a carpet backing of 2mm for an overall thickness of 12mm. You will also have to add the length of carpet that particular gripper is holding. If that gripper is holding a certain length there is a certain weight rating applied to it. Using a smaller gripper might not be enough to hold the tension in the carpet.
Let me ask the supplier for their recommendation and as soon as I have the information I will get back to you.
