Hi, we have installed vj panels with liquid nails and screws that goes in the studs. How long should we wait for before hanging TV on the wall panels?
Evening @sud
I wouldnt recommend hanging the tv off the panels themselves
that would be tempting fate ![]()
If you are hanging the tv off the studs then really you could start as soon as your paint drys
You could do it now but think it would be a tidier job painting first and hanging the tv afterwards
The screws will be the long term holders of the VJ board.
Are you going to do the hidden cabling? I know Bunnings sells these DETA White Brush Wall Cover Plate - Single Pack plus a hanger DETA Plaster Clip Bracket - Single Pack I have used them before and they make for a tidy job. Id also suggest to run an extra drawwire so you can run other cables later on
And yep I ended up glad I had done so as well.
Hi @sud,
When it comes to VJ panels, it's important to note that, like plasterboard, they are not really designed to hold heavy items like a TV directly. The panels themselves are typically not strong enough to support the weight of a TV.
As Dave mentioned, the best approach is to hang your TV directly from the timber studs behind the panels. If the studs aren't in the ideal location for mounting, you can install a bridging piece of timber between the studs. This will provide a solid surface to securely fix the TV mount onto. Here's a previous discussion on the topic: How to mount a TV.
Sorry my question wasn't clearly formed. Tv would definitely not hang on vj panels. We have marked the studs before the panel installation.
Yup, cable hiding mechanism already installed. Appreciate you sharing about that.
Really good to know about bridge thing! Thanks for sharing that.
Ok so tv can go anytime since we are hanging it on studs. So that's sorted.
Now about painting the panels, are these rollers suitable for painting the
panels?
Morning @sud
The pic made me smile, I was looking for how fluffy it was hahahah You have all the info there bar the fluffyness
It looks like it will be fine, the fluffness will help paint within the VJ gullys is all. ![]()
Hi @sud,
Typically, you would use a higher nap roller, somewhere in the 10-15mm range, however you can get the job done just fine with these rollers, it may just take a little extra time because they won't hold as much paint.
If you want to use the one you have there are no issues, but these UNi-PRO 230mm 10mm Nap Microfibre Paint Roller Covers would be ideal.
HI Jacob, thanks for you response. The said VJ panels are easycraft vj panels.We are thinking to apply enamel paint on it. Is that suitable choice for the panels? If so, then is the nap you suggested appropriate for enamel paint?
Suman
Hi @sud,
Enamel paint is usually used for doors, door frames, window frames, timber trims and skirting boards and is not what I would recommend for this application.
You're better off using Dulux Wash&Wear Interior Paint with a compatible primer such as Dulux 1Step Prep Primer, Sealer & Undercoat.
When using the Dulux Wash & Wear, the rollers I have mentioned are perfect.
