Hello!
Long time lurker, first time poster.
I am wanting to install storage cupboards/drawers in the space under my stairs. It's an awkward space and I have never figured out how it should be best used, so usually it just has crap shoved under it.
Ideally I would like at least 3 sections, the tallest being a 'broom cupboard' which can store the dyson stick vacuum (i will get a powerpoint installed in it also) and cleaning items on a shelf if there is space). Other cupboards will be used for...dunno, maybe linen cupboard items or kids toys/ shoes etc.
Inspiration photo below, I love the look of doors/drawers with no handles. I also love the look of acoustic panels for door fronts, but it might be overkill with the existing wooden diagonal of the stairs
I think due to the depth I will have to build something from scratch and have it on runners, but would be open to altering a flatpack system (kaboodle?) if this will be substantially easier.
Approximate dimensions are
diagonal length - 2718mm
width- 2160mm
height- 1650mm
depth- 1000mm
The stairs have open risers, so I think I my first step (hahahahhaha) would be to add timber risers and then plasterboard underneath?
I would say I have an intermediate skill level and can figure out most things. I have ample tools etc, but am also willing to purchase extra tools as needed to ensure a high quality build (thinking I need a brad gun....)
Looking forward to hearing from the community! I did read another post from 2021 with a similar project, but there wasn't an outcome
CURRENT UNDER STAIRS
INSPIRATION
Hello @minnieS
Welcome to the Bunnings workshop community. It's sensational to have you join us, and thanks for sharing your question about building a cupboard under your stairs.
Thank you for providing the measurements under your steps. Please give me some time to draw up a framework for your cabinetry. As soon as it is ready, I will post my recommendations here.
Thank you for your patience.
Hello @minnieS
Thank you for your patience. I've placed some diagrams sample images below to give you an idea of how you can maximize the storage under your stairs. I suggest using either Plywood or MDF to construct your cabinet. You'll notice that the measurements I've placed are slightly different from the ones you've provided and that is because I've made the cabinet 32mm shorter from the bottom. This will give you space to adjust the cabinet should some of the internal measurements of the space be different from the front. Please note that this is just a suggestion, and I recommend adjusting the sizes to your needs.
Please have a look at the images and tell me what you think. I also suggest having a look at this discussion - How to build storage cupboards under stairs? by @dannyrus.
