Hello @Hayaimi
I suppose you could use a higher sheen of paint if the finish is very obvious. Just keep in mind that melamine surfaces will have a higher surface sheen on its surface because of the type of material used. A painted surface will always have a different finish and matching it with your tables finish will be very difficult.
Okay thanks so much
I just applied some Earl’s WAXSTIX WAX Touch-up Crayon (no beeswax) onto the chip, how can I making the chip not “ghosting” through?
Hello @Hayaimi
The Waxstix touch up crayon is made for light touch ups and disguising slight to moderate scratches on laminated and timber floors. It is not made to cover up large gouges or very visible surface damage. A better technique would be to paint the damaged surface and use the Waxstix to add highlights and colour to the damaged surface. Please make sure to remove the Waxstix on the surface before you paint the damaged portion.
Do I paint it before applying the wax or should I use the putty of the same series, same color, instead?
Cuz I’m still concerned that the repair look unnatural if I only paint it before applying the wax.
Also what did you mean by “Use the Waxstix to add highlights and colour to the damaged surface.”?
Hello @Hayaimi
Either repair methods will work as I mentioned earlier in the discussion, but it's important that the wax be removed thoroughly otherwise anything placed on top of the wax surface will slide off. The Waxstix can be used in conjunction with other Waxstix colours. To add or colour the surface using the Waxstix to disguise, cover and camouflage the damage. Just keep in mind that this is a cosmetic fix and not a permanent repair. It will be difficult to get the exact same finish as it is a laminate surface. Replacing the entire surface would be the ideal solution.
