I'd like to install this on my existing shelving mounts to hang some clothes on:
https://www.bunnings.com.au/flexi-storage-2-4m-stainless-steel-telescopic-hanging-rod_p2662025
Here is the setup I currently have:
Would these brackets work with what I have?
Hi @ALimestoneWall,
The Flexi Storage Home Solutions White Hanging Rod Bracket attaches to the bottom of the Flexi Storage Home Solutions 350mm White Double Slot Wire Shelf Bracket. Although your brackets are similar, some slight differences make me think that the bracket you've pictured is not this item.
An easy way to tell would be to look for the slots I've marked below in the image. If your brackets do not have these slots, it might be worth picking up one of the new brackets to see if it fits your wall strip. Your brackets might have been from an older model before they made the addition of the slots for the hanger.
Thanks for the response.
Just to make sure we're on the same page, as you've circled the bottom of the brackets, I am wondering if the Home Solutions brackets will fit on my existing strips.
The ends do look quite similar:
Is that what you meant?
Sorry, I interpreted it the other way around, @ALimestoneWall.
In the absence of Home Solutions being open during the holiday period, the only way to tell is to try them. Home Solutions' newer items are often backward compatible with their older wall strips. Given the similarity, I would suggest that there is a good chance the new brackets will fit your wall strips. If not, you can return them for a refund.
They do fit on my existing ones, but strangely enough https://www.bunnings.com.au/flexi-storage-home-solutions-white-hanging-rod-bracket-2-pack-white_p266... doesn't fit in the bottom of https://www.bunnings.com.au/flexi-storage-home-solutions-350mm-white-double-slot-wire-shelf-bracket-.... I had to take hammer it in with a rubber mallet, and then the second metal bit (without the hole) wouldn't stay secure in its hole.
Hi @ALimestoneWall,
Is it locked in place well enough for use?
If the hooks have been tapped into place and there is tension created, it should work.
Are you happy with the tension that has been created?
If not, can you upload an image so I can assist further?
Let me know what you think.
Hey Jacob.
I spoke with a staff member in store and he said what you said: as long as there is tension (in the right direction), it will stay in place, which makes sense. However, he did also say that they can be really difficult to push in.
