Hi, we are trying to use the space, how can we put a hanging rail at the bottoms like what we have now? or any other suggestions? thank you guys
Welcome to the Bunnings Workshop community @ClaireChen. It's terrific to have you join us, and many thanks for your question about installing a hanging rail.
How is the hanging rail fixed at the top? Does it make use of that middle divider as the mid-support point? If you can take a picture of how the top rail connects in the middle and how it's supported, it will give us a clue as to how you can construct the bottom rail.
Is it mainly more hanging space that you're after? If so, the additional hanging rod might be the answer, but we do have an extensive range of wardrobe storage solutions that you could utilise in the bottom section. Also, check out this Top Ideas post on 5 ways to add more storage to your wardrobe.
I look forward to seeing how that top rail is connected on the sides and in the middle. I'll then be able to suggest the appropriate products to use for your new bottom rail.
Hi Mitchell,
Thank you for getting back to me.
I have attached photos of other parts of the wardrobe. I am planning to have hanging rails in the middle and build simple draws on one side.
Hi @ClaireChen,
If you're fixing the hanging rail between two walls, you will use oval flanges. If you need to attach the rail to the shelf above, you can use pillar ends. Or, if you need to support a longer rail length in the middle, you can use a pillar centre.
Please let me know if you have questions.
Hi Mitchell,
Thank you so much for you guidance. is the wall safe to drill through to fix the oval flanges? As the above rail, they have been fixed on a piece of wood, which should be glued and also nailed through ( i am just guessing).
Hello @ClaireChen
If you are drilling into timber there should be no problem in installing the oval flanges. However, if you are installing into a plasterboard wall, I suggest using Ramset Super Wallmate Toggle Anchor. The self-drilling Ramset Toggle Anchor is suitable for heavy-duty fixing in plasterboard for cavity walls or ceilings.
Thank you so much Eric!
Hi Mitchell,
In terms of load bearing I would like to know which one is better, fixing to the wall or fixing to the shelf above.
Welcome to the Bunnings Workshop community @sred. It's fantastic to have you join us, and many thanks for your question about hanging rails.
If the rail is less than a metre long, it’s fine to attach it directly to the walls. However, if the rail is longer than a metre, you’ll need to add a mid-support bracket to the underside of the shelf to help distribute the weight. If the shelf itself is well-supported and can bear the weight of the clothes, you can install all your brackets directly to the underside of the shelf without needing to attach anything to the wall. Just ensure that the shelf can handle the load before proceeding.
Both methods are perfectly fine, but depending on the length, you might need to use a bit of both.
Thanks Mitchell. The length of the rail needed for the wadrobe area is around 127 cm and the thickness of the shelf above is 1.5 cm. What do you think is better fixing to the wall or fixing to the shelf above. I have attached the image of the wadrobe.
