How to wall mount TV on steel studs?
soapit
Hello,
im looking to wall mount a 43 inch tv on a steel frame wall looks like the tv will be just under 10kgs.
Ive purchased this wall mount https://www.kogan.com/au/buy/kogan-full-motion-adjustable-wall-mount-32-75-tvs-b/
most online guides recommend some variety of toggle? But earlier bunnings recommendtion seems metal screws will be ok?
https://www.workshop.bunnings.com.au/t5/Living-and-Bedroom/Wall-mounting-a-TV-on-Metal-stud/m-p/4624...
the bracket extends so i certainly dont mind going a bit over the top with the fixing so it doesnt break under the lever of it.
cheers
Al
MikeTNZ
Amassing an Audience
Re: How to wall mount TV on steel studs?
Hi @soapit,
Just FYI, you can get drill bits called a reduced shank type, even though the actual drill part diameter is larger than 13mm, the shank (that goes into the chuck) will be a maximum diameter of either 10mm or 13mm, depending upon which one you select.
Cheers,
Mike T.
