how to properly do wainscoting on a plastered masonry wall
monter
Community Newcomer
Hello there.
I'm looking to do wainscoting full height to a 2250mm by 4480mm bedroom wall behind a bed head (it is a very low traffic area). The wall is double brick and plastered (float and white set), and has subsequently been painted about 2 years ago. The exterior leaf of bricks has been waterproofed and is texture coat rendered.
I've already purchased the pine mouldings (porta 31mm by 15mm) and have not yet started to prepare and cut them to size. I await the advice requested in this post first. Per the design that best suits the wall design the largest frame will be 1700mm by 1200mm.
I've looked at various online content for how to undertake this diy project but I'm struggling to see ones that have my scenario being the double brick masonry wall. I've since looked and other videos when installing more extensive paneling suggest battening out the wall. My initial thoughts though seem this may over engineer my application of such light decorative moulding.
In all videos I note the use of a nail gun. Is the nail, pin gun able to be used on masonry? Therefore my main queries centre more around affixing to the masonry wall in the most effective and efficient manner. Happy also to receive any further tips on completing this project nicely as well.
Thanks for any assistance and feedback. I attach a markup of the drawings, the pine moulding product number, and a inspiration pic of what I'm trying to achieve.
Re: how to properly do wainscoting on a plastered masonry wall
Welcome to the Bunnings Workshop community @monter. It's amazing to have you join us, and many thanks for your question about wainscotting.
You’ve more or less hit the nail on the head, so to speak, with why you’re struggling to find examples of this being done on plastered masonry walls. Traditional wainscoting relies on very fine trim work, and that trim is normally fixed with small brad or pin nails into plasterboard or timber laths, with adhesive doing most of the long-term holding. The nails are really there to hold everything in place while the glue cures and to keep joints tight and aligned. That works well on stud walls, but it becomes much more difficult on a double brick wall with a thin skim of white set over the masonry.
A pin or brad nailer isn’t suitable for masonry, and you generally won’t have enough plaster thickness to safely take even the shortest brads without either blowing out the plaster or hitting brick almost immediately. That’s why you don’t see wainscoting applied directly to masonry very often. Historically, it was done over lath and plaster, and in modern homes, it’s almost always over plasterboard on timber framing.
In your situation, if you’re set on applying the pine mouldings directly to the wall, the only realistic fixing method is construction adhesive. Modern adhesives are quite strong and are commonly used even on plasterboard walls, but normally in conjunction with brad nails. Here, the adhesive would be doing all the work. You would need to dry-fit everything very carefully, apply adhesive sparingly but evenly, and then hold each piece in position with painter’s tape until the adhesive fully cures. This makes the process slower and more fiddly, but it is achievable if you work methodically and patiently.
The main risk to be aware of is that if you get partway through the job and decide it isn’t working, removing glued mouldings will almost certainly damage the plaster surface. You should expect that the wall would then need patching or possibly re-skimming to repair any torn or damaged areas. That doesn’t rule the project out, but it does raise the stakes, so careful planning and test fitting are important.
Battoning out the wall would be the more robust and traditional approach for masonry, as it gives you something solid to pin into, but for light decorative mouldings in a low-traffic area it can be considered overkill. If you’re happy to accept the slower pace and higher reliance on adhesive, and you take your time with layout and alignment, you can still achieve the look you’re aiming for directly on the plastered masonry wall.
