I'm building an outdoor seating bench using 50mm by 200mm sleeper timbers. I would like to have a nice and smooth finish, is it ok to sand them using an orbital sander? Google search tells me varied opinions citing it's poisonous and not to sand vs some people saying it's ok to sand with mask on. Either ways, appreciate any advice on achieving smooth finish, thank you.
Welcome to the Bunnings Workshop community @kprasann1979. It's wonderful to have you join us, and many thanks for your question about sanding sleepers.
Sleepers treated with CCA should only be cut to length wearing appropriate PPE gear and used in retaining walls. Any benches, play equipment or items you'll come in contact with regularly need to be constructed from non-CCA treated timber.
If you're planning on sanding sleepers smooth, I'd advise not using any that are treated with CCA. H4 Sienna MicroPro Sleepers would be an option, provided you wear a dust mask, as they don't have an arsenic-based treatment. A non-treated hardwood would also be safe to use for your project. If you want a smooth finish and are painting the seating, you could consider using H3-treated LOSP pre-primed timber. Have a read through this article on How to choose the right timber for the job, as I trust you'll find it helpful.
Thank you Mitchell, the product I bought from Bunnings is "
The details page of the product says it can be used for DIY furniture and treatment says it's CCA, now your reply worries me
so Bunnings is wrong in that advice and CCA must be avoided ? Thank you.
I/N:
Hi @kprasann1979,
I'll need to follow this up, and confirm the suitability of this product for garden furniture.
Many thanks for your patience.
Hi @kprasann1979,
I've confirmed that CCA-treated timber can not be used to construct furniture. I've passed your feedback on to our team so they can adjust the product details on the website.
I apologise for the inconvenience. Please let me know if I can assist in returning the sleepers and selecting a more suitable product.
Thank you for the tips
Thank you Mitchell, have put the sleepers aside for now, too bad I realised after cutting them all at various angles , so doubt if I can return to Bunnings. Will check in-store for any alternate options as the bench I was about to make based on a YouTube channel called Rouge Engineer is really good and drives me to DIY esp when I have all the tools with me. Appreciate your inputs and clarification.
Am going ahead with H4 Sienna MicroPro Sleepers as you mentioned, thank you much
Hi @kprasann1979,
We'll be refunding those sleepers for you, and it's not an issue that you've cut them. Let me reach out via private message to get some details from you and next time you're in-store, I'll get the team to return them for you. No need to bring the cut pieces back, either.
