Hello everyone,
I'm trying to build a deck in our alfresco. At this point, it's still on the planning stage. I've seen a few posts here and there on this forum and would very much appreciate some further inputs to more experienced people than me.
My background: I work in the IT industry and "hardware" isn't really my thing lol. Anyway, I've built a few benches, and tables (nothing fancy) but not really built anything as big as an outdoor deck.
Project Alfresco: We have a small alfresco that my wife insists should have a deck. I agree, and I want to build it myself. Here's some bit of a challenge. The brick height is low, and also, "not even" from the side near the wall (corner of the doorway), it's around 130mm slopes down to 125mm the other side. Also, what would look good:(1) building the deck only on the slab of the alfresco, or (2) including the one outside as well?
Should I build a deck to included the ones outside the Alfresco slab?
height is 130mm from the left sloping down to 125mm to the right
Need suggestions on best way to build it, should I use this? https://www.bunnings.com.au/tuffblock-300-x-300-x-90mm-instant-foundation-system-deck-support_p24103... shour I do something else? Open to any suggestions at this point since this is my first build.
thank you.
Hello @yeahboo
That decking frame looks great! I recommend using CAgroup 50mm x 20m Bearer Protector G-Tape over the frame before you start putting on the decking panels. It will provide extra protection to your decking frame.
I still have some of the Bitumen Rubber that @MitchellMc to use on the ones that touch the uneven slab. Will that be OK to use too? I plan to use it all up on the ones exposed to the rain
Oh wow! What a beauty! This clearly shows what I need to do! Thank you @MitchellMc !!!
Hello @EricL @MitchellMc ,
So, I finally started putting boards. The first board I placed is the straight one that's parallel to the wall. Since I was excited, I made a mistake of doing the predrilled holes exactly in line with the screws I used for the frame. I'm using 65mm decking screws, and visually, it will hit the screw.. See below:
Screw up!
So then, I decided to move up the screws... but then, while drilling the 2nd hole, the drill bit snapped!
So now, the questions I have are:
Thank you in advance for your advise!
Hi @yeahboo,
I have made this mistake many times before. Don't stress; it happens.
Step 1 is to remove the first screw and lift the board so you can get the snapped drill bit out. If there is any part of the drill bit exposed on the bottom, then you can use a pair of pliers to pull it out. If not, then use a Nail Punch to tap it out from the top.
Now that the drill bit is out, as long as the holes line up with the joists, then you could use this board elsewhere. If not and you have to use it here, then you can just angle your pilot hole ever so slightly so that the shaft of the screw passes beside the screw in the frame.
You will notice the slight angle of the screw head, but if you bore a slightly deeper countersink, then it will be almost imperceptible.
Another option is to use a Plug Cutter in a size larger than the countersink hole to cut a plug from elsewhere, then glue that plug in to cover the hole in your decking board.
Let me know what you think and if you require further assistance, please don't hesitate to ask.
Hello @MitchellMc ,
I'm now at this part of the boarding process! lol (man, this project has been going on for a while haha)... However, I need advice on tackling it, as there might be a better way to handle it than what I'm thinking the solution is. As you can see on the pictures below, I may need to "carve" a square around the post per board. (I have long boards of 4.2m length)... on the first board that "touches" the post (post is on left of the board), I see no issue as it's just a small cut to cater with the post... on the second board, the cut will be a bit wider to "hug" the board, but I'm thinking since I have a frame there, it won't be an issue with having a thinner part of the board there... Do you think that's a good approach? is there a better way for me to handle this? Also, is it correct that I need a jigsaw for the "carving" out of the square? or I need a different tool?
This one will have a smaller cut
This one will have a bigger cut...
PS: I don't know what software you used for me to visualise the framing and boarding around the post, I wanted to create the one I was thinking of.. but I'm guessing you understand what I mean. haha.
Good Evening @yeahboo ![]()
Sometimes projects just seem to take a little longer then what we expect, life gets in the way or we just heitate over a harder part (Thats where I am at the moment with one of my projects
So here is my project of building an outside bench, you will see around half way down the page the same issue you are running into. Yours is easier as your posts are square to the boards
The principal is the same. I would probarlly use a thicker piece of timber then I have (id use the same timber you have for under your deck, just to be consistant)
Outside bench Just ask if what I did dosnt make sense
BTW your deck is looking good ![]()
