How to insulate exhaust pipe from diesel heater?
laurat1989
Cultivating a Following
Hi guys, just looking for some ideas to help with making the exhaust pipe not as hot, it will be going outside under an outdoor blind and just dont want the kids touching either either
AlanM52
Re: How to insulate exhaust pipe from diesel heater?
Hi @laurat1989,
Can you post some photos please.
Re: exhaust pipe from diseal heater
Hello @laurat1989
Thank you for sharing your question about your diesel exhaust pipe. In order for our members to get a better idea of its proposed position, would it be possible for you to post a few photos of where you plan on positioning the exhaust pipe? Once we see the size of the pipe, we'll be able to offer recommendations on how to cover or place a barrier to prevent it from being touched.
laurat1989
Hi guys please see photos. We ideally dont want to have the outdoor blind up...could we some how get the exhaust pipe out of this wooden wall to the outside?
laurat1989
Hello @laurat1989
Thank you for posting those extra pictures. I propose using an Exhaust Wrap 2" X 15', Fibreglass Black W/Stainless Ties - CAL-H1011BK. Built for automotive use it should provide excellent insulation and lower the outside temperature of the exhaust pipe.
Let me call on our experienced members @Dave-1, @Nailbag, @TedBear, @JoeAzza and @SRBENET for their recommendations.
If you need further assitance, please let us know.
AlanM52
Tagging @EricL,
I see no reason why you can't do that...
What is the diameter of the exhaust pipe?
I have started window shopping for things we might need, all a bit tentative at this stage.
Here's another idea I like this one.
https://altrish.co.uk/2019/10/08/installing-an-externally-mounted-diesel-heater-for-heating-the-work...
Have to go the footy is on... I'll be back.
Good Evening @laurat1989
Mmmm little warning bells started going off in my head about carbon monoxide buildup/poisoning. Fully admit I dont know enough to give an opinion but would definently check out the ruling. There have been too many instances of enclosed spaces being heated via wrong type heaters for the space.
Mainly cautious is all.
Just went looking up info about it, its mainly mean for tents, caravans/rv'd and boats. Local councils will have a set of rules so you could check there to make sure its allowable.
To answer your question (yeah if its allowable lol ) I would go through your timber fence, Would treat it like a short horizontal flu for a fireplace. So a smaller centered tube with a larger one around it. That way there is an air gap insulation between the two so your timber wont cook/blacken. I would then make the exhaust go straight up with the same chimeny style to just above the eves of your house so the funes exit away from you.
Scandia 1m External Flue Extension is the type of tube I am thinking of.
Hello @laurat1989
I totally agree with @Dave-1's caution in regards to your heating installation. In the interest of health and safety please make sure to follow the installation instruction of your heater. I would also double check the rules and regulations of your local council in regards to its installation. Accidental carbon monoxide (CO) poisoning is a serious and potentially fatal risk that occurs when CO gas builds up in enclosed or poorly ventilated spaces. Carbon monoxide is colourless, odourless, and tasteless, making it especially dangerous because it cannot be detected by human senses.
Hi @laurat1989
Your scenario isn't ideal as the only real way to protect the wooden wall is more distance between the exhaust. But that mean lifting the blind which opens up its full width.
The Exhaust Wrap 2" X 15', Fibreglass Black W/Stainless Ties - CAL-H1011BK @EricL suggests will significantly reduce the radiant heat and definite;y something you should apply. Then its a matter of closely observing the surrounding area for heat damage.
For an alternative solution, you could combine the wrap and lift the lid a little more. Then fill the gap with a few door snakes. Just keep its distance well clear of the pipe.
