Low-level deck between brick walls
aaron11
Budding Contributor
Deck build went great!
  • 250-400mm high (ground is on a slope)
  • Size is 4600 x 2270mm
  • Earth underneath
  • both 4600mm sides are concrete/brick walls
Dynabolted ledgers onto either wall. Used brackets bolted into pre-existing pavers to support the posts down the centre. New 120mm merbau for the trims, reclaimed merbau for the main deck space. Steps took a bit of figuring but turned out great.
Re: Low-level deck between brick walls
Love your work @aaron11, thanks again for sharing.
What do you think were the most important lessons you learned during the project that might assist others tackling decking projects down the track?
Love your work, @aaron11! That reclaimed timber is just sensational. I'm really pleased this project worked out well for you, and good luck in the competition!
