I am building a leantoo and am concreting the stirrups into the ground.When I put the timber uprights into the stirrup it says to use a M10 bolt, but can I use a 100mm hex screw instead?
Hi @Martinb,
Thank you for your question on hardware used with stirrups.
It is always best to use the recommended hardware dictated in a product's installation instructions as the relevant testing and engineering has been conducted with that specific hardware in mind.
A bolt and nut will pinch the stirrup around the post, utilising the strength of both uprights, whereas a hex screw will pull the timber towards one side of the stirrup creating an imbalance.
Is there a specific reason that you ask? Maybe a space issue?
Let me know, I'd love to help you find a solution that works.
Thanks Jacob, no I just have some left over hex drives and was just wondering if I could use them. But you answer is appreciated and will be used.
Martin
