Outdoor kitchen and entertainment area
raymao268
Cultivating a Following
I have been thinking of upgrade my backyard entertainment area and build a outdoor BBQ kitchen for quite some time, last year I finally decided to put it in action.
Things have been done so far:
  • Upgraded pergola roof to better heat resistaint sheets, it is now much more comfortable during a hot summer day.
  • Upgraded the lightling and installed a ceilin fan, it worked very well during last Christmas.
  • Did the plumbing work including both hot and cold water pipes and drain pipe which connected to the existing kitchen drain.
  • Built the half wall for the kitchen area
To be done
  • Build a decking floor across the entire pergola area
  • Build kitchen cupboard and building BBQ and Wok Burner
Chellenges
  • In oder to ensure the new decking floor is not higher than the house floor, the whole decking is very close to the ground. The lowest point is only about 90mm from paving surface to the top of joist. I am using 70mm timber for the joist support system.
Anyone has any suggestions and/or previous experiences, I'd love to hear. Thank you.
 10167463970542539.jpg135514022306634392.jpg285791885861046254.jpg469929062547260044.jpg602863975091113076.jpg607051661585715963.jpg
Re: Outdoor Kitchen and Entertainment area
look great - where did you get your kitchen from?
Welcome to the Bunnings Workshop community @swindail.
It's fantastic to have you join us. Let me mention @raymao268 to see if they can answer your question for you.
There is the possibility that the kitchen was from Kaboodle as they offer a range of products which are suitable for undercover alfresco kitchens. Here's a helpful guide on what to consider. There is also a great modular range from Alfrescoplus to make building an outdoor kitchen super simple.
We look forward to hearing more about your outdoor kitchen project and encourage you to let us know if you have something to share with the community or need any assistance.
lost89577
Growing in Experience
Re: Outdoor kitchen and entertainment area
i have a concern because from the photo the existing floor drain was there to help remove excess water from back yard run off. now you have repurpose it the excess water will pool under your new deck.
raymao268
I didn't actually cover the existing water drain, so the condition for water runoff shouldn't be changed. In fact, I made a removable cover for each floor drain, so it can be checked and cleaned if need to.
