Paling warping
mike88
Paling warping
Anyone have experience glueing back paling? Would Gorilla Glue hold it back in place?
Re: Paling Warping
Hi @mike88,
Welcome to Workshop. It's great to have you join the community.
I suspect that fence palings warping over time is a common problem so I'm sure there will be plenty of interest in this topic.
Let me tag a few helpful members in @Brad@r23on@ProjectPete@Prof and @Noyade to see what they would do.
Feel free to post anytime you need a hand or have a project to share.
Prof
Becoming a Leader
Re: Paling Warping
Why not just screw them back in place.?
mike88
Re: Paling Warping
Hi @Prof  - thanks for the response; warping alongside the adjoining palings not the rail and overlap of palings isn't much hence trying to avoid screws.
Prof
Becoming a Leader
Re: Paling Warping
Ah..I see what you mean..bit of a tricky one..I'm thinking that there's nothing really suitable for a permanent cure..
Once palings are warped there's not much you can do except replace them...
Noyade
Re: Paling Warping
"overlap of palings isn't much hence trying to avoid screws."
Hi Mike
Overlaping as seen in No.1?
Are some of the boards bending sideways as in No.2?
All I can think of is screwing all the top ends of the boards into a piece of wood at the back - and painting the exposed unpainted edges.
But it still probably won't look that good. 😞
Noyade
Re: Paling Warping
The power of pine warping.
Seen at the delivery end of the local Bunnings store...
mike88
Re: Paling Warping
Thanks @Noyade - good illustrations, exactly like No. 1. I am able to push them back, hence I was thinking of using strong wood glue (with a clamps until dry).
r23on
Re: Paling Warping
Hi in the past I have used polyurethane adhesives which works well, however like all treated pine no matter what you do warping will take place.
I take it the fence is treated pine? The other factor is that the fencing is cut so thin hence warping is common. I have noticed in some places in NSW the palings are around 10mm thick reducing some warping.
hope this helps
mike88
Re: Paling Warping
Thanks @r23on - yes the fence is treated pine, think you are spot on the palings are to thin.
