How did you trim out the window frames to your new wall panels?
Hey It looks great. can you help me I don't know where to start. I read somewhere that some structures inside are support for the van. How do I know what to remove and not weaken the structure. cheers deb
I actually just put the wall panels around the window frames and then filled and gapped around the edges to give a reasonable smooth finish. Not perfect, but once you paint over it, it looks pretty good.
@deborah Most vans are pretty robust and an aluminium box in their own right. You can remove most stuff. I do tend to leave in all the upper locker cupboards as I don't want to damage the roof and cause leaks. But anything lower down can come out. I think you'll get a feel for what is flimsy and not supporting anything and what is integral to the structure.
Just a heads-up to visitors of this discussion that @Peggers has shared photos of a couple of other caravan renovation projects he has worked on.
Thanks again for sharing your great work.
Hi @Peggers. Your caravan looks amazing. I'm just stating out renovating my first caravan. It's an old Millard I'm hoping to permanently live in when she's finished. Her names Peggy. Just wondering if you have any tips or advice for someone starting out on the renovation? Thanks.
Hi again @beckyboo,
I've tagged Rob in your other discussion post so I'm sure he will respond there as soon as he can.
And do check out the recent interview we did with Rob as it contains some caravan renovation tips which might help get you started - https://www.workshop.com.au/t5/Blog/Physical-creativity-on-the-road/ba-p/17663
Thanks,
Hi @Peggers,
Great to see the popularity of your caravan renovation project on Instagram today. Congratulations!
Looking forward to seeing your next project.
