What fence for DIY installation?
badmojo
Building a Reputation
We’re planning on putting up a short fence in front of the porch along the brick on the ground on below picture. Is there fencing you can suggest to screw on these bricks and mount on?
We saw this Jack Screen-up products but they are tall. We intend to cut these to about 1.2meters. Any thoughts?
https://www.bunnings.com.au/search/products?q=Jack&brandname=Jack&sort=BoostOrder&page=1&supercatego...
Re: What fence for DIY installation?
Hi @badmojo,
Unfortunately, there would not be a fencing material that I am confident mounting to bricks alone. You can see they are set in place with mortar, so there is not a lot of weight to them.
Instead of mounting to the bricks, I would suggest you check out the range of easy-to-install fencing from PEAK No Dig Mesh Fencing.
They are installed by driving a 350mm Post Spike into the ground, then inserting a 1200mm Black Steel Fence Post, which your fencing panels will attach to.
Check out Peak No Dig Fencing Installation for a visual guide of the installation process.
You can also have a play with the Peak No-Dig Designer to help you select the required materials.
badmojo
Thanks @JacobZ for the suggestion. Will check them out.
