Might be a silly question, but whats the best method to connect two 90 x 45 bearers to timber stumps of 100 x 100?
If they are to sit both on top of the post, are metal straps an acceptable method of attaching, or do i need to notch the post only slightly on each side, then coach bolt through both bearers? If i go option 2, does this stop it being as strong as if they were glued and nailed?
any other suggestions appreciated!
There are no silly questions @Crash76.
Let me tag @ProjectPete who might like to kick off on this topic.
Hi @Crash76
This is the strongest bearer to stump connection - https://www.workshop.com.au/t5/Gallery/Decking-frame-bearer-stump-rebate/cns-p/33659. It's not necessary/ideal to fix the bearers on top of the stumps, that'll increase the depth of the hole and length of bearer and amount of concrete needed to set each post too.
Can you send a sketch of your design to better understand how you're going about this? Generally speaking you'd want to use a wider bearer like at least 120mm but ideally 140mm. Take advantage of using ledgers on walls, etc where possible.
Totally agree with Jason and Pete here, having a pic or something to go on would be awesome.
I also don't know that strapping timber together is the best idea anyway, as strapping has a habit of being tensioned on one side and loose on the other as the timber moves?
I hope that makes some sense......
@MikeTNZ M12 Cuphead Bolts, either Galv or Treated Pine even better, secure the bearer to the stump/post - I was just showing the joinery.
HI Pete, is there a maximum you can notch into the post? In this picture it looks like you have gone in half the width of the post ,D/2 ?
Hi @liv,
Let me mention @ProjectPete so he is alerted to your question, I trust he'll be able to answer it for you.
Yes @liv D/2 as you've put it. Don't exceed half the width of the stump/post
