I am looking to replace the carpet in a unit with laminate flooring and have come across this product - "Smart Home Products 2.42m² Amazon Aquaguard Waterproof Hybrid Planks".
Would you be able to advise if this would come with any Acoustic Sound tests certificates as Strata are looking for some evidence to meets the impact sound ≤ 62 dB (LnT,w) under the ACCC / NCC / AAAC standard.
Thanks in advance.
Welcome to the Bunnings Workshop community @dwz. It's fantastic to have you join us, and many thanks for your question about Hybrid flooring.
On the SmartHP product page, under the resources section, you'll find the acoustic test reports, which shows the flooring system achieved Ln,w = 42 dB under ISO 10140-3 / ISO 717-2, which is well below the ≤ 62 dB requirement in the NCC/AAAC guidelines. Please note the result was measured on a 150 mm concrete slab with a drop ceiling system, so performance may vary if the ceiling construction differs from the tested assembly. A copy of the reports can be downloaded from the SmartHP site.
