Lofts as an after thought can be expensive and difficult to install
So I've included a simple lightweight steel (Cold Formed Section) staircase that the average DIYer should find relatively simple & cost effective to knock up with a basic tool set
If you played with a mecanno set as a child
then this is for you
https://dovedaler.com/2012/08/16/workbench-news/
A few points to consider
@Andy_Mann Hmmm.I try to see the good in all deeds, professions, advice,etc,etc..but unfortunately sometimes those that involve referrals, commissions, kickbacks,etc
the doubt but lingers (and it shouldn't ?)
If you have a vested interest then there should be disclosure.
@BibbyKat To complete the Stairs add Mdf Risers and Treads and Plasterboard to the walls Cheers
Thank you .. That diagram/stair is exactly how I was picturing it! All my plans will be thought of and tossed around .. and nothing is being "started" till next year .. depending, of course, on finances/costings/quotes.. (that nastly little topic always rears its ugly little head) !!![]()
I am feeling a little confused here. I think someone was just being a kind human being and very nice to an older lady to what she could expect if she made a studio/loft for herself. I don't think there is an ulterior motive. I did not take it that way.
Am I confused here ???
@BibbyKat there is no need for confusion and the Sketches & Data are there for you to enjoy and use :-).
Continuing on the DIY Loft series
I have taken a step back to where the loft would be ideally placed within the roof space
A few points to consider when deciding on a location
Images are for Complete & Exploded views
Hope you find then useful
Thanks for sharing @BIM_Engineer.
In your experience, do most Australian homes have sufficient head space in the roof for a loft?
@Jason I get asked about lofts all the time.. happy to share
Most Australian homes are configured to the above rear plan layout
In the above the loft space is basically governed by roof type (trusses excluded), pitch (25 deg+), and block width 15m+.
I should also mention these are gross dimensions, deductions will need to be made for floor depth which is function of clear span (Roof Clearance Height- floor depth= actual loft height).You will notice when having the floor beams/joists over internal walls (ie passages) below lessens the span and the depth of the floor beams/joists
