i have purchased a very heavy round mirror which I want to hang. The mirror weighs 23kg and the instructions say to hang straight on the D-rings and not to add a string.
if I used 2 wallmates (15kg load each) into the plaster would this be sufficient?
open to other easy suggestions, very inexperienced handywoman here
Hi @mmryan
I propose using Ramset Super Wallmate Toggle Anchor in combination with the Everhang 20kg Heavy Duty Solid Wall Picture Hanging Hooks. The toggle will provide a more robust anchor, and the hooks are rated for 20KG each.
I also suggest having a look at this guide: How to hang just about anything by @Adam_W.
Hi @mmryan
My first question has to be, when you say " into the plaster" do you mean a plaster board hollow wall or do you mean plaster on brick solid wall?
Just a plaster wall
Sorry @mmryan
That leaves me as in the dark as before, if you tap on the wall, does it sound hollow or solid? Just trying to ascertain which as the two different types of wall require different anchors.
