How do I take out a screw that is stripped?
JanaF
I am replacing the hinges on my internal doors. I've come across quite a few screws that have either been stripped that I can't get them out. They are flush with the wall so there's nothing to grip on to.
Any advice would be greatly appreciated! Thanks in advance!stripped screw.jpg
Re: How do I take out a screw that is stripped?
Hello @JanaF
I understand your frustration when screw heads get stripped off. I suggest using the IRWIN 3 Piece Screw Extractor Set 1876224. IRWIN Screw extractors are designed to remove damaged screws and small bolts. It's a simple three step process drill the top of the screw, flip the bit and extract.
If you have any other question we can help with, please let us know.
JanaF
Thank you kindly for your advice. I'll give that a go.
Thanks!
Jana
