How to clean windows with security grills?
kylie26
the one storey house we are living in have patterned security grills on every window.
the outside of the windows are filthy, how can they be cleaned/ scrubbed as there is no way to get the grills off
Prof
Re: how to clean windows with security grills
Hi kylie26...
I have used with success a hose spray gun..the type that has a cylinder underneath..Like this type  https://www.ebay.com.au/itm/335346011731?itmmeta=01JEM2B6SXQYCARYAFSGSQQ5XM&hash=item4e142e0e53:g:5Z...
You fill the cylinder with a detergent and select the type of spray on the selector that you want..
Unfortunately normal detergents tend to leave streaks..but what I use doesn't leave any streaks..
All you have to do is dissolve a dish washer tablet in a jar ( like a gherkin size jar.) in some hot water and pour that into the cylinder on the sprayer unit..
You will most likely use up that small cylinder a few times so just keep an eye on the flow..
The best way to do it is to just spray water on the windows first..wait for 1/2 hr. and then  spray the detergent and leave to drain off..
You should have spotless windows.!
Prof...
Welcome to the Bunnings Workshop community @kylie26. It's fantastic to have you join us, and many thanks for your question about cleaning windows.
It's great to see that @Prof has already provided a helpful response.
Have you checked to see if the windows can be removed from inside? Typically, sliding windows can be removed by gripping the frame on either side and pushing it up into the top track. This allows clearance on the bottom track for the bottom of the frame to be pulled out of it. You can then lower the window down and out of the top track.
Remember to enlist a hand if they are larger windows, and remember that the glass can shatter easily if knocked. Wear PPE whilst doing so, including safety glasses, cut-resistant gloves, a long-sleeved shirt, trousers and enclosed shoes.
Hi
this is what I normally do. However some of the windows have been fitted with windowsills on the inside that are too high to leave sufficient clearance to remove the window pane. What would you do in this situation. Thanks
Hello @bridgirl
Welcome to the Bunnings Workshop community. It's wonderful to have you join us.
I can understand how frustrating it can be when you can't reach certain parts of your window to clean. In order to give our members a better idea of your windows configuration, would it be possible for you to post a photo of the window frame? Once our members see what it looks like they will be able to offer recommendations on how to move forwards. Is there any chance the windowsill can be removed?
If you need a hand posting the photos, please let us know.
AlanM52
Re: How to clean windows with security grills?
Hi @kylie26,
Same question as @EricL, are they sliding windows.
@bridgirl, Interesting... can you post photo(s) lower down so we can see the windowsills.
@Prof, Some good cleaning tips 👍
