Hey, new day, new issue to fix ![]()
We’ve had some torrential rains here and we had a lot of water ingress through one of the windows. The water was accumulating on the bottom of the frame. It is an old aluminium window and the most likely culprit seems the cracked seal (or is it caulking?) all around:
Just wondering what is the best product to use to fix this? I wanted to just put a layer of clear all purpose silicone sealant on top of the old cracked caulking or is it better to remove and apply a fresh one? I’ve got a Polyfilla interior/exterior gap filler - is it something I could use or is there a better product specifically designed for this application?
Thanks,
Tom
Hi @tom138
Thanks for sharing your question about fixing your leaking window. I suggest removing the old, cracked silicone with either a CornerTape Professional Silicon Remover or a Craftright 5-in-1 Scraper. It's important that the surface your sealing is totally clean and free of debris. The Polyfilla gap filler will work, but I suggest having a look at Selleys 310g Translucent Roof And Gutter Silicone Sealant. It’s a neutral (non-acid) 100% silicone that offers superior adhesion and resistance to lifting, with a flexible seal. Guaranteed for 25 years against cracking, crumbling and peeling away.
Here is a handy step-by-step guide: How to silicone seal a bath (the technique used is applicable to your window frame)
I also suggest having a quick look at this guide: How to apply silicone sealant by @lifestylebymari.
Hi @EricL ,
Thanks for the links and suggestions!
I do have this one lying around:
Is that similar to the Selley’s one?
Thanks,
Tom
Thanks @EricL, yes it says interior and exterior.
I am having issues with access as this is second floor. I’d like to take the window apart so that I can gain access to the side that doesn’t open.
Is the idea to unscrew these screws on top and bottom, remove the post in the middle, lift the panel and remove or is there more to it?
Am I going to be able to put install it back or is it one of those things that is impossible to put back together once it’s disassembled?
Hi @tom138
You've hit it right on the head regarding the window assembly. Once you take it apart it will be nearly impossible to reassemble it at height. These windows are often assembled on a table using a custom frame to hold all the parts in place.
If you decide to use a ladder and do it from the outside, I suggest reading this guide - How to use ladders safely. by @Adam_W. Please make sure to take all necessary precautions when working at height.
However, if you are not comfortable working in high places like me, I suggest engaging the services of a handy person with the proper equipment.
Hi @EricL,
I am glad I asked as I was just going to proceed with disassembling it!
I did seal what I could, although I had to go mostly over the existing cracked seal. I did find the scraper you recommended useful but I just couldn’t reach to some places even from a ladder. I just need it to last a year or two before we replace all windows. Let’s see how it holds up when the next big rain comes.
Thanks again,
Tom
