Hello ![]()
I am trying to undertake a hybrid flooring project throughout the house. I am not sure what product I can use to raise the floor height by 15mm to match the new height (tile area plus hybrid floor boards) of the tile area. I am also not sure if a reducer strip is a good solution between two floors without raising them. Any advice on the two will be highly appreciated.
Welcome to the Bunnings Workshop community @amsclarke. It's wonderful to have you join us, and many thanks for your question about changing floor heights.
To clarify, do you need to raise a floor by 15mm so you can then add the Hybrid flooring over it and achieve the same height as an adjoining floor? If so, STRUCTApanel 12 x 2400 x 1200mm H2 Non-Structural Panelling will get you within the realms of using a cover strip.
I think raising the floor would be well worth the effort as a 15mm height difference between floors would present a trip hazard as the cover strip would be at an aggressive angle.
Hi Mitchell,
Thanks, yup it's to achieve the same height as the adjoining floor. Would installing these structpanels on concrete require any special tools?
Hello @amsclarke
You can either drill the panel into the floor or use adhesive to fix it in place. No special tools are needed to install or cut the panel.
Thanks Eric, will give this one a go
