How to prevent pigeons nesting under solar panels?
Madden
Re: How to prevent pigeons nesting under solar panels?
@CSParnell
Wise words. And thank you
CSParnell
Just passing on what I've learnt and ensuring safety 😀
Madden
Thank you for all your suggestions. Unable to try any as yet, as we have 2 babies to leave the nest. Checked with Solar company and warranty ok as long as we don't touch the electrics. Will advise what works when we have succeeded with stopping them returning to nest.
MikeTNZ
Hi @Madden,
Sorry to come into this topic so late.
One term, bird spikes........
We use these on our transformers and associated cables here in New Zealand.
Check this out: https://www.bunnings.co.nz/jack-250-x-110-x-70mm-stainless-steel-pest-control-bird-spike-4-pack_p304...
Bear in mind this is the NZ Bunnings site, but the product is the same.
If birds can't land, they can't roost, because their wings won't close when they land.
All you need is a pack of cable ties and possibly some supports for the spikes.
Is this anything or nothing?, if not, let us know.
Mike T.
Hi @Madden,
Hope all is well. Just checking in to see if the babies have left the nest as yet? Have you been able to make any progress?
There's been considerable interest in this discussion so I'm sure other community members would appreciate you keeping us updated with your chosen solution.
Thanks,
Madden
Slow progress babies have flown nest.  Put up two owls one stopping them getting under solar panel other to stop perching on roof.  Had some success only two keep coming back.  Going to try spikes on roof to stop them perching.
Hello @Madden
Thank you for the update, it's good to know that the owls have reduced the number of pigeons coming into your solar panels.
65john
How to stop pigeons from getting underneath my solar panels
Re: had to stop pigeons from getting underneath my solar panels
Welcome to the Bunnings Workshop community @65john. It's great to have you join us, and many thanks for your question about pigeons.
Pigeons are notorious for taking shelter under solar panels, which can cause droppings, noise, and even damage to wiring. To stop them, you want to make it physically difficult for them to access the space and make it less attractive for nesting. Installing mesh or wire barriers along the edges of your panels is often the most effective method. Some people use bird spikes or angled metal strips, but be careful to ensure any fix doesn’t interfere with panel performance or maintenance access. Regularly checking for early signs of nesting and keeping the area clean also helps deter them.
For more detailed strategies, check out this discussion on How to prevent pigeons nesting under solar panels, which has some great advice, and also this best Advice article on How do you keep pigeons away?
