Stupidly, I attached a drawer backing the wrong way around 🙄
The plastic screws are firmly in place now...
What is the best way to remove the screws without damaging them/so I can reuse them ?
Hi @Else,
They look to be plastic plugs, and hopefully, they are not one-way fittings. The only way I can think of is to get a couple of flat-head screwdrivers, slip them under the head, and try to lever it out enough to get a hold of it with pliers. Even if you damage the head slightly on removal, it likely won't affect its holding capacity when reinserted.
Let me tag @AlanM52 and @Noyade to see if they have any thoughts.
I think I'd like to try a very small pair of side-cutters, just under the plastic head edges - then lift/pry.
Don't squeeze the arms! 😉
If elevated a few mm - then try a claw hammer.
Whatever you do, let us know how you got on.
Cheers.
Hi @Else,
Try two lengths of string, one wrapped around to the left the other to the right.
I use the very strong waxed thread from my Speedy Awl.
