How to replace LED downlights?
Orlando
Building a Reputation
Hi guys, can anyone tell me if LED downlights are hardwired into the roof electrics, or do they come with a plug to connect to a socket? I ask because, looking through Bunnings downlighting on-line, I noticed an Arlec with a plug on the end. The downlight in my bathroom seems to have failed - it began flickering; now it's just got a pale glow. It's a 'Jin Hang' downlight. Never having encountered this sort of downlight before, I thought perhaps it would have a removable bulb; so I freed it from the ceiling hole. It came away with its cable that disappeared up past what looked like a tube of fire retardant; so I couldn't see what it was connected to. Fortunately, the manhole is close to that light, so I may be able to see for myself. Just thought I'd ask the experts first. Thank you.
Re: LED Downlights
Hello @Orlando
The only way to tell If the downlight has a plug-in feature would be to see it in your ceiling cavity. Some units have long cables while others don't, some will have it printed on the back of the casing saying that it has a plug-in feature. Just a friendly reminder that any electrical work must be carried out by a registered electrician for safety and compliance.
If you wish to upgrade to a plug-in downlight for easier maintenance in the future, you can ask your sparky to install a plug in the ceiling where you can just plug your new modern downlight in.
Orlando
Re: LED Downlights
Thanks Eric - guess I'll have to get in the roof space - at my age that's going to be fun!
Re: LED Downlights
Hi @Orlando,
Before going into the roof space to check your downlight, make sure you turn off the electricity at the main switchboard, as ceiling cavities can contain exposed wiring and hidden cables that pose a serious shock risk. Roof spaces also present significant physical hazards: it’s easy to lose your footing, step between joists, and fall through the ceiling, which can cause serious injury and major damage to your home. Always move slowly, keep your weight over the joists, and take a torch or battery-powered light for visibility. If navigating the roof space feels unsafe or you’re not confident working around electrical components, it’s best to enlist the help of a licensed electrician or professional who can carry out the inspection and replacement safely. Safety should always come first.
