What roller brush for Ryobi stick vac?
wellplanted
Recently I purchased a Ryobi R18XSV9PET142BLK  I/N: 0657564. I am finding the Floor head a bit heavy and large for my day to day use, which is where I use it the most. So my question; is there a Ryobi Roller brush that would be compatible with this Stick Vac? if so then I could swap over to the dual floor head for a thorough clean.
Keeping my fingers crossed.
Re: What roller brush for Ryobi stick vac?
Hello @wellplanted
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your Ryobi stick vac.
After a thorough search I'm afraid there is no lightweight vacuum head available for the Ryobi R18XSV9PET142BLK. Its proprietary fitting does not allow other types of vacuum fittings to be used on it. I can only suggest using the Mini powered brush bar that came with the set as an easier way to use the vacum stick.
