Is this a sewer cleanout / relief gully or stormwater pipe?
LorenClayton
Having an Impact
Hello
My house is at the top of a battleaxe lot, with 3 houses in the lot all behind one another. I'm the top house.
Camera work revealed that the kerb adaptor drain runs across my yard to my back neighbour - the middle house. I had a look over the fence and saw this, so I'm hoping this is a stormwater pipe and not sewerage, as it appears to be directly in front of where the drain pipe is.
It's an unusual situation. The lot has a mild negative grade from the street at the front. I'm the top house, and so stormwater flows from my house to the houses behind me. Or itimage_2024-12-04_035404206.png would, if it wasn't for a great big retention wall behind my back fence. My back yard floods as a consequence. (I've already looked this up and Council won't get involved).
I'm wondering legally if I can connect my back drain pipes to this kerb drain pipe, which I'm assuming is shared? Or does the owner who installs the pipe "own" the rights to it?
Why though would the house behind me connect to an upward grade kerb? They'd be better off connected to the street behind them, where their drainage would be gravity fed, unless they were unable to get permission from the bottom house, as it would have to go through their yard. Really confused at this stage.
I'd also appreciate some advice re drainage options. Moreton Bay Council won't offer any advice without me disclosing my address, which I don't want to do until I have to. Their website says they don't allow charged systems to kerb for houses with negative grade and that the only option is an engineered rubble pit which won't do much at all.
Re: What is this? A sewer cleanout / relief gully or stormwater pipe?
Hi @LorenClayton,
It sounds like this situation could benefit from the expertise of a professional plumber. Since making connections to drainage systems like this can involve legal and technical considerations, a plumber will be able to assess your options and help you plan a proper solution. They can also help you determine whether this is a shared stormwater pipe or another type of drainage system, and advise on the best way to connect your back drain pipes. Additionally, a plumber will be knowledgeable about local regulations and council requirements, ensuring any work is done correctly and legally.
I'd recommend having a plumber come out and quote for the work. You'll then get a good idea of what work will be involved, what options you can consider, and what it will cost.
