Hi all,
i purchased the Lamar smart lock and have it all installed and setup in the Grid Connect app.
I’ve searched and searched for the function to unlock the door Int the app, but can’t find it anywhere.
They advertise you can do this but I can’t find the inductions to do it. Their support won’t respond to emails either.
I don’t want to return it as it’s a lot of working installing a front door lock.
any help would be greatly appreciated.
thanks
Hi @Caleb01,
I don't do Grid Connect so I will redirect you to resident specialist @CSParnell.
Ok looking into these locks here is what I have found out for you.
Here is a summary of the Lemaar Smart Lock unlock methods, formatted ready for a blog post or review.
5 Ways to Unlock Your Lemaar Smart Lock
If you’ve just installed the Lemaar Rectangle Smart Lock or are looking into buying one, you might be wondering exactly how you get in. It actually offers five different entry methods, giving you plenty of backups if you forget a code or a key.
Here is the breakdown of how to open it:
1. Fingerprint (The Quickest Way)
Located right on the handle (or top panel), the biometric sensor is the fastest entry method. It works just like your phone—press your thumb or finger against the sensor, and the handle engages immediately. You can register multiple prints for different family members.
2. PIN Code (Best for Guests)
The lock features a touchscreen keypad for entering a standard PIN (6+ digits).
* Pro Tip: It has a "Scramble" feature. If someone is watching you, you can type random numbers before or after your real code (e.g., 123 + REALCODE + 890 + #). As long as your real code is in the sequence, the door will unlock.
3. RFID Key Fob (Easiest for Kids)
The lock comes with small RFID tags (fobs). You simply tap these against the keypad area to unlock the door. This is a great option for kids or elderly family members who might struggle with remembering codes or using the fingerprint scanner.
4. The Grid Connect App (Remote Unlock)
You can unlock the door from your phone, but there is a catch: to save battery, the lock "sleeps" and isn't always listening for commands.
* How it works: The visitor must press 9 + # on the lock's keypad. This sends a "Request to Unlock" notification to your phone. You simply tap the notification to let them in. It acts more like a silent intercom than a standard remote control.
5. Mechanical Key (The "Fail-Safe")
If the batteries die completely, don't panic. The lock includes a traditional mechanical key barrel (usually hidden at the bottom or under a cap). Always keep a spare key outside the home (e.g., in your car) just in case!
Bonus Feature: Emergency Power
If you lose your mechanical key and the batteries are dead, there is a USB-C port at the bottom of the lock. You can plug in a portable power bank to wake the screen up and enter your PIN code.
Sorry it's a bit text book I have not used these ones, I use wifi internal Tuya locks which are similar but different at the same time.
Tuya is something I do... in conjunction (as you know) with Alexa & SmartLife and other related stuff like eWeLink.
There is a plethora of Alexa compatible devices out there (mind boggling) suitable for anyone's budget.
I did not mention Google Home (compatible with Alexa devices) because the Google TV streamer includes a smart hub.
Here I am last year excited about setting the Google TVS before moving to the lounge room.
That setup is on the computer desk return... my sandpit.
Waiting for Google Home to sniff out all the devices and appear on the shortcut menu.
Device list not as yet setup.
Looks like this... Alexa on Win11 Pro desktop.
I should mention our house is not actually a smart home because mostly all the devices are outside.
Sorry about all that... by now everyone has left the room.
Hi @Caleb01,
Unfortunately, like the others, I have not used this lock and consequently can only base things on the instruction manual, which is essentially what CSparnell has attached.
Most times, the best thing to do if you are struggling with Grid Connect products is to give their team a ring on 1800 826 859 in Australia and 0800 003 329 in New Zealand, so their technical support team can talk you through the process. Due to the complex and wide spanning nature of the system, the team who work with it everyday are the best people to speak with. Their operating hours are Mon - Fri: 8:30am - 5:00pm AEST.
If you have any issues getting in touch, please let us know so we can assist further.
